Lefebvre Posted January 16, 2019 Report Share Posted January 16, 2019 How can you change a 2018 Beta Evo 200 to a 250 power wise? If not possible, can you improve the power quite a bit with other changes to the engine? Thanks a lot for your help. Quote Link to comment Share on other sites More sharing options...
Markws80 Posted January 16, 2019 Report Share Posted January 16, 2019 Sell the 200 and buy a 250 1 Quote Link to comment Share on other sites More sharing options...
mcman56 Posted January 16, 2019 Report Share Posted January 16, 2019 Beta 200 is a small bore 250 so just add 250 top end. 1 Quote Link to comment Share on other sites More sharing options...
cleanorbust Posted January 16, 2019 Report Share Posted January 16, 2019 3 hours ago, mcman56 said: Beta 200 is a small bore 250 so just add 250 top end. Carb, exhaust and CDI same as 250? 1 Quote Link to comment Share on other sites More sharing options...
cleanorbust Posted January 16, 2019 Report Share Posted January 16, 2019 4 hours ago, Markws80 said: Sell the 200 and buy a 250 That really does seem the best advice. Trying to make one bike into something it's not is usually expensive and not as effective as hoped Quote Link to comment Share on other sites More sharing options...
dan williams Posted January 16, 2019 Report Share Posted January 16, 2019 The market for used 200s is really good. 1 Quote Link to comment Share on other sites More sharing options...
section swept Posted January 16, 2019 Report Share Posted January 16, 2019 Changing your 200 into a 250 will possibly create issues when you want to sell it. Potential buyers would go for the unadulterated 250. As already mentioned there will be other parts needed and the cost ( unless you are minted in which case you wouldnt be asking this question) may well not be worth it, Getting more power from your 200 may be the better option, ensuring everything's spot on with the rolling stock, wheel bearings, seals, brakes, suspension and steering. Turning to the engine and transmission, ensure you have the optimum final drive ratio and chain and sprockets are all good. Potentially down sizing the chain to a few grades down ( lighter weight ) and sprockets to match if available. The engine obviously needs to be in excellent condition, crank and crank seals and all gaskets in servicable condition. Carb jetted correctly, going for a larger choke card may reduce the available torque. Exhaust clean inside and the correct tail pipe installed. Obviously a porting job done properly will release a little extra power, but care needs to be taken as having gobs of power is no replacement for torque ( pulling ability). Contact a proven trials engine tuner for advice. Using race fuel or octane booster will help in your quest. Fuel oil mix ratio is all important to help give that little bit extra. You’ll end up with a nice non threatening 200 with power approaching that of or slightly more than a 250, might be a bit more revvy though. ?? 1 Quote Link to comment Share on other sites More sharing options...
collyolly Posted January 17, 2019 Report Share Posted January 17, 2019 It has been mentioned in previous threads about the lack of available bikes in Canada but I would suggest the best route would be change the whole bike unless of course you enjoy a challenge. Quote Link to comment Share on other sites More sharing options...
copemech Posted January 17, 2019 Report Share Posted January 17, 2019 someone said that the crank and flyweights are different. I am sure the gearing is as well. 1 Quote Link to comment Share on other sites More sharing options...
