larrywyo Posted January 21, 2019 Report Share Posted January 21, 2019 Hello- I am stalled in rebuilding a spare kt250 engine that was seized. I have rebuilt the lower end, and before I spend the money for a bore and new piston, etc., I want to make sure I can get a spark. I have the flywheel installed, and I have a CDI unit, but I do not have a coil. I'm looking for an aftermarket coil but I can't find out whether I need a 12v or a 6v coil. I know the lights are 6v, but the ignition coil on the magneto may not be 6v as well. Does anyone know which voltage coil I need, or maybe which coil specifically I could use? I found a couple of reasonable coils on ebay that say they are compatible, but I'm skeptical. And of course the used kt parts on ebay are usually shot AND super expensive. I think it's a cartel...LOL Any help would be appreciated, Larry Quote Link to comment Share on other sites More sharing options...
feetupfun Posted January 21, 2019 Report Share Posted January 21, 2019 (edited) I'll have a look at mine and see if says anything useful on the coil Edited January 21, 2019 by feetupfun Quote Link to comment Share on other sites More sharing options...
konrad Posted January 21, 2019 Report Share Posted January 21, 2019 (edited) Ignition coils for CDIs are neither 6 volt nor 12 volt. CDI coils work on a completely different principle than "induction coils". The capacitor inside the CDI gets charged to on the order of 200 - 300 volts, and then is discharged into the ignition coil. Technically, such ignition coils are "pulse transformers". They typically have somewhere around a 1 : 100 (primary : secondary) turns ratio. Their primary resistance is very low (usually under 1 ohm). I just searched "CDI ignition coil" on eBay and found something for $8.25 USD shipped from China. Better yet: https://www.ebay.com/itm/IGNITION-COIL-YAMAHA-TTR125-TTR125L-TT-R125-TT-R125LE-2000-2009-2011-MOTORCYCLE/281087430819?hash=item41721dd0a3:g:iFIAAOSwDk5T1Lw~:sc:USPSFirstClass!55066!US!-1 Edited January 21, 2019 by konrad Added content 3 Quote Link to comment Share on other sites More sharing options...
larrywyo Posted January 21, 2019 Author Report Share Posted January 21, 2019 thanks to Konrad and feetupfun for the replies. I did look at the ebay link, and that coil, though cheap says it is not compatible. But, I have a feeling that the compatibility may be based on physical dimensions and not on electrical factors. I think I'm going to order one from ebay that is like $19 but says compatible. I can make it work physically one way or another, so I've got my fingers crossed that it will make a good spark, and if so, I can proceed. I'll let you know how it works out...Larry 1 Quote Link to comment Share on other sites More sharing options...
