doogle Posted January 11, 2006 Report Share Posted January 11, 2006 Has anyone raised their mudguard yet on the 4RT. Want to mine for the Hurran on Sunday, but I am worried it will catch on the exhaust when the forks compress. Its never been a problem on my other bikes, but the 4rt pipe gets a lot hotter. Also I take it you run a Jitsie air filter without the fire proof cage that you put the original in. As my new Jitsie filter does not fit in it. Thanks Dave Quote Link to comment Share on other sites More sharing options...
simtech Posted January 11, 2006 Report Share Posted January 11, 2006 I have always run my 4RT with 10mm spacers on the mudguard with no problem at all. Bit concerned that you're not using the fire proof cage though as I know of someone who removed that part on the Sherco and melted the filter due a 'Spit Back' through the carb !!!! Quote Link to comment Share on other sites More sharing options...
the artist formerly known as ish Posted January 11, 2006 Report Share Posted January 11, 2006 Bit concerned that you're not using the fire proof cage though as I know of someone who removed that part on the Sherco and melted the filter due a 'Spit Back' through the carb !!!! <{POST_SNAPBACK}> fire proof cage ? not seen one of those on the sherco, nor has the parts book, could you explain what your talking about ? Quote Link to comment Share on other sites More sharing options...
jsp Posted January 12, 2006 Report Share Posted January 12, 2006 my jitsie filter fits in the cage ok, are you sure they have sent you a 4rt one ? how do you raise the front mudguard then ? as mine does sometimes start cloging up Quote Link to comment Share on other sites More sharing options...
simtech Posted January 12, 2006 Report Share Posted January 12, 2006 Machine up some small ally spacers - Sherco was a problem when a Mikuni carb was fitted Quote Link to comment Share on other sites More sharing options...
doogle Posted January 12, 2006 Author Report Share Posted January 12, 2006 Cheers for the replies, I will raise the mudguard before Sunday. It's definately a 4rt filter as it has the holes in it for the bolts to go through, instead of the lip to attach the cage on. Cheers anyway, I will probably just run it with the standard one. Quote Link to comment Share on other sites More sharing options...
