boner Posted January 29, 2019 Report Share Posted January 29, 2019 I’m trying to identify an imperial bolt and was wondering if someone could tell me what the upper section of the bolt with no thread on is called? Is it different to a normal fully threaded bolt, ie all the way to the head? ive got the length / diameter / tpi sorted, just need one with the thread cut to the right length on the body of the bolt. Thanks Boner. Quote Link to comment Share on other sites More sharing options...
ric h Posted January 29, 2019 Report Share Posted January 29, 2019 Bolt shoulder. Quote Link to comment Share on other sites More sharing options...
boner Posted January 29, 2019 Author Report Share Posted January 29, 2019 Thanks Rich. Quote Link to comment Share on other sites More sharing options...
trialsrfun Posted January 29, 2019 Report Share Posted January 29, 2019 13 minutes ago, boner said: I’m trying to identify an imperial bolt and was wondering if someone could tell me what the upper section of the bolt with no thread on is called? Is it different to a normal fully threaded bolt, ie all the way to the head? ive got the length / diameter / tpi sorted, just need one with the thread cut to the right length on the body of the bolt. Thanks Boner. Hi Boner, yes shoulder is correct. A bolt is threaded part way along its length. If fully threaded up to the underside of the head then it is a set pin. Either type is measured from end to underside of head so length does not include the head. 1 Quote Link to comment Share on other sites More sharing options...
konrad Posted January 29, 2019 Report Share Posted January 29, 2019 In the aircraft world it's called the "grip". http://spenceraircraft.com/hardware/fasteners-screws-bolts/airframe-bolt.html 1 Quote Link to comment Share on other sites More sharing options...
boner Posted January 29, 2019 Author Report Share Posted January 29, 2019 Thanks for the input. The terminology I was looking for was ‘part threaded’ referring to the shoulder. I’ve hopefully found what I’m looking for and ordered it. Quote Link to comment Share on other sites More sharing options...
peterb Posted January 30, 2019 Report Share Posted January 30, 2019 The area above the threaded part of a bolt is known as a shank. Bye, Peter B. 5 Quote Link to comment Share on other sites More sharing options...
copemech Posted January 30, 2019 Report Share Posted January 30, 2019 3 hours ago, peterb said: The area above the threaded part of a bolt is known as a shank. Bye, Peter B. to me as well Quote Link to comment Share on other sites More sharing options...
oz thumper Posted January 30, 2019 Report Share Posted January 30, 2019 In the UK a fastener threaded all the way was referred to as a "Set Scew" or 'Machine Screw" , Bolts always had a shank and a threaded section I believe to reduce the stress concentration around the head when subject to high torque and high tension loads. 2 2 Quote Link to comment Share on other sites More sharing options...
mattylad Posted January 30, 2019 Report Share Posted January 30, 2019 One language so many options! Quote Link to comment Share on other sites More sharing options...
bezaboy Posted January 30, 2019 Report Share Posted January 30, 2019 2 hours ago, oz thumper said: In the UK a fastener threaded all the way was referred to as a "Set Scew" or 'Machine Screw" , Bolts always had a shank and a threaded section I believe to reduce the stress concentration around the head when subject to high torque and high tension loads. Correct and how we sold them here in UK 1 Quote Link to comment Share on other sites More sharing options...
ChrisCH Posted January 30, 2019 Report Share Posted January 30, 2019 1 hour ago, mattylad said: One language so many options! Yes, it's nuts! 1 Quote Link to comment Share on other sites More sharing options...
zippy Posted January 30, 2019 Report Share Posted January 30, 2019 Imperial bolt identification: Well if it is powerful and down right scary, it is probably a Darth Vader bolt 1 Quote Link to comment Share on other sites More sharing options...
b40rt Posted January 30, 2019 Report Share Posted January 30, 2019 (edited) Minor hijack, any one found a source for Allan button top bolts ? Edited January 30, 2019 by b40rt Quote Link to comment Share on other sites More sharing options...
trialsrfun Posted January 30, 2019 Report Share Posted January 30, 2019 (edited) 47 minutes ago, b40rt said: Minor hijack, any one found a source for Allan button top bolts ? FWB Products @ Stoke on Trent https://www.fwb.co.uk/ or Barfast http://home.btconnect.com/barfast/ these people also stock metric fine, I highly recommend Britannia Fasteners Burslem though they do not have a website. Edited January 30, 2019 by trialsrfun Quote Link to comment Share on other sites More sharing options...
