Cota 49
baurespdx
Hello everyone, I recently added a cota 49 to my stash of Montesa’s. Does anyone on here have one and could send me some photos of their bike so I can figure out where some of the frame brackets go and other parts. The bike came in a box and I am trying to repiece it together. Thanks!
I'm sorry I don't have anything other than lots pictures from the internet that you probably already have.
I do though  have a Fura 50 and a Cota 50 in bits waiting for me to get round to fixing.
I have the JLO / ILO three speed engine on both bikes although one is badged as Montesa.
If there is anything specific you wanted to know please do ask.
  • Thanks 1
Big Shiney Bike. Thanks
The Cota49 motor is based on the JLO/ILO G50 Piano. My son (baures PDX) and I split the case and it looks like the top end and clutch need a redo!
Any good sources of parts for the G50?
Also any technical info on the engine would be appreciated.
Thanks.
  • 2 months later...
If you could explain the kick mechanism.
Gracias.
  • 1 month later...
As much as I know the basic principle is that the bike is supposed to be ridden like a bicycle.The assembly in your picture when assembled properly (mine is a sealed unit that doesn't come apart) should allow the pedals to be locked in place while the engine runs.
the pedals have a locking device that lets both pedals fold around so they are not 180 degrees apart.
Hope that makes sense, I'm not sure if I understand that myself.
Thank you. All of that makes sense. We are hopefully done with the engine and plan on putting it on frame soon. Our fingers are crossed.
  • Thanks 1
  • 4 months later...
Our Cota49 leaks oil from the clutch actuating pin’s passage on the left side of engine. There seems to be 2 slots on one of the pins that looks as if there ought to be 2 Orings. Any idea on what we can do to stop the oil leak? Not sure if Orings are specified.
Thank you.
  • 1 month later...
Hi fellows. Still haven’t got around to addressing this issue. We did hear from a Montesa fan in Spain that actually drilled out the passage’s diameter to allow the O-ringed mini shaft to fit in.
The passage is a hair above 5mm and not too sure if there is a way to ream the passage and maintain a smooth round surface so O-rings will glide as mini shaft moves laterally.
Any ideas?
thank you.
