Changing Crank Seals - Cota 247 - 1971
DanielHowden
Yes they can be changed without splitting the cases. You will need a magneto flywheel puller for the magneto flywheel, and a good stout puller to pull the primary gear on the clutch side. There are seal housings that unbolt from the main engine cases making seal replacement very simple.
Sam
