Mountainbrad Posted February 28, 2019 Report Share Posted February 28, 2019 I'm about 220lbs and an intermediate rider. I have a 2018 TRS 300RR. I'm trying to learn hopping my bike but having a hard time. My suspension rebound is set quite dampened which suits the West coast of Canada where the mountain climbs are long, steep and rooty. When I jump down hard and compress the suspension i find it doesn't spring back fast enough to elevate the wheels off the ground. Is this normal? Even when i compress and pull up hard the tires barely come off ground . Should i make the forks and ring coil more "springy". Any suggestions and methods appreciated. Quote Link to comment Share on other sites More sharing options...
faussy Posted February 28, 2019 Report Share Posted February 28, 2019 (edited) With the right technique it doesn't matter what your suspension is set like, suspension rebound only plays a small role in aiding lifting of the bike (weight transfer plays the biggest role). However, at 220 lbs and an intermediate rider id consider looking for a stiffer spring than standard at least in the rear, there's a good chance you're bottoming out when you jump down hard on the suspension, and this certainly won't be helping your hopping woes. The speed of rebound is dictated by the spring stiffness as well as your damping after all Edited February 28, 2019 by faussy Quote Link to comment Share on other sites More sharing options...
