mickmc Posted March 3, 2019 Report Share Posted March 3, 2019 Hi, I am changing the kickstart spring on a beta 80, I have drained the oil and the coolant, can I take the cover straight off without taking the water pump cover off, any information on this appreciated, thanks Quote Link to comment Share on other sites More sharing options...
mudslugger Posted March 3, 2019 Report Share Posted March 3, 2019 There’s no need to drain anything, just lay the bike on it’s side remove the clutch casing with the water pump attached. If you’re careful you should be ok with the gasket, just ensure you align the water pump shaft fork up when putting the casing back on. Check your coolant and oil levels when complete. Quote Link to comment Share on other sites More sharing options...
