iliketurtles Posted March 6, 2019 Report Share Posted March 6, 2019 Hey guys! I picked up a Tiger Cub Trials recently and looking to mod the suspension to more better/modern-ish. For the front end I'm looking at baby cerianis as an option. Has anybody went this route fro a front end? Or would a set of 35 Betors be a smarter option. Thanks in advance! Jeff Quote Link to comment Share on other sites More sharing options...
brucey Posted March 7, 2019 Report Share Posted March 7, 2019 (edited) Depends how much money you want to spend and how original you want the bike. For something over £1000 Duncan MacDonald can supply new MP forks and yolks I fitted Betors (from a Montesa) to 1 Cub and Marzocci’s to my Armac Cub. Both out perform my ability. They are also a vast improvement over the original heavyweight forks! It may take a bit of fettling to make them fit and to get the length right. Hope this helps. Edited March 7, 2019 by brucey Quote Link to comment Share on other sites More sharing options...
naichuff Posted March 7, 2019 Report Share Posted March 7, 2019 Duncan MacDonald supplies REH fork not MP These transform the front end I have used MP 32 mm and Marzocci's But I do not ride the bike I leave the to someone that uses it and tweak the bike to suit him Quote Link to comment Share on other sites More sharing options...
brucey Posted March 8, 2019 Report Share Posted March 8, 2019 12 hours ago, naichuff said: Duncan MacDonald supplies REH fork not MP These transform the front end I have used MP 32 mm and Marzocci's But I do not ride the bike I leave the to someone that uses it and tweak the bike to suit him My mistake. Duncan does indeed supply REH forks (which look beautiful by the way) ??. Quote Link to comment Share on other sites More sharing options...
naichuff Posted March 8, 2019 Report Share Posted March 8, 2019 They are The rider of my Cub says the action is better than his GasGAS and it showed up how bad the rear was Quote Link to comment Share on other sites More sharing options...
teamferret Posted March 8, 2019 Report Share Posted March 8, 2019 If you come across some original REH or MP's with knackered stations, it is easy to through the stations and damper rods away and replace with more modern stuff, I normally use Marzochi but other brands are available Quote Link to comment Share on other sites More sharing options...
iliketurtles Posted March 16, 2019 Author Report Share Posted March 16, 2019 Thanks for the advice guys! Quote Link to comment Share on other sites More sharing options...
detective 21 Posted April 2, 2019 Report Share Posted April 2, 2019 On 3/7/2019 at 7:20 PM, brucey said: Depends how much money you want to spend and how original you want the bike. For something over £1000 Duncan MacDonald can supply new MP forks and yolks I fitted Betors (from a Montesa) to 1 Cub and Marzocci’s to my Armac Cub. Both out perform my ability. They are also a vast improvement over the original heavyweight forks! It may take a bit of fettling to make them fit and to get the length right. Hope this helps. what mods did you have to do to fit the montesa front end, and to make the right length? thanks Quote Link to comment Share on other sites More sharing options...
