Tom_H123 Posted March 10, 2019 Report Share Posted March 10, 2019 Went for a quick ride this morning on my bike, 10 minutes in the bike made a loud pop/bang sound and then cut out and wouldn’t start again... I tried kicking and kicking and occasionally made another pop noise Crome the exhaust, any pointers as to what it could be? Any help is appreciated cheers Quote Link to comment Share on other sites More sharing options...
slack Posted March 10, 2019 Report Share Posted March 10, 2019 Try the woodruff key Quote Link to comment Share on other sites More sharing options...
robido Posted March 11, 2019 Report Share Posted March 11, 2019 (edited) Whiskerd plug Edited March 11, 2019 by robido Wrong spelling Quote Link to comment Share on other sites More sharing options...
Tom_H123 Posted March 11, 2019 Author Report Share Posted March 11, 2019 (edited) 19 hours ago, robido said: Whiskerd plug 23 hours ago, slack said: Try the woodruff key Checked spark plug... tiny bit of carbon buildup so removed it still didn’t start, checked the fly wheel to see if it was spinning freely and it wasn’t... any other ideas? Edited March 11, 2019 by Tom_H123 Sorry getting used to using this Quote Link to comment Share on other sites More sharing options...
slack Posted March 12, 2019 Report Share Posted March 12, 2019 Hi Tom did you remove the flywheel or did you just check to see if it was spinning on the end of the crank?? Quote Link to comment Share on other sites More sharing options...
Tom_H123 Posted March 13, 2019 Author Report Share Posted March 13, 2019 On 3/12/2019 at 9:29 AM, slack said: Hi Tom did you remove the flywheel or did you just check to see if it was spinning on the end of the crank?? Just checked to see if it was spinning freely on the end of the crank... however I did stop the engine from turning over and tried to turn it with the flywheel nut off and it wasn’t budging i was struggling to get the flywheel off or will I need to get it off to make sure? Quote Link to comment Share on other sites More sharing options...
