Cylinder rubbers
jeffk
Anyone know the factory position of the cylinder rubber pieces on a 1974 ty 250? I should have taken a photo 3 years ago but did not. I've seen at least 3 different photos. Not a big deal but as a restoration I would like to make it factory correct. thanks.
I've got an unmolested early 434 model motor (never even had the cylinder head off) that I can take photos of, but I suspect that there are actually two different cylinders that came on the first model TY250 so that might be what is causing confusion. One type has a circular un-finned section above the exhaust port. Is that the type of cylinder you have?
3 minutes ago, jeffk said:
Thanks for taking the time to take the photos. I appreciate it! I can now see where they go.
Jeff
You are welcome. I took a series of photos of three different cylinder types many years ago when I was helping someone work out which model cylinder they had on their TY250
  • 4 weeks later...
