steve0 Posted March 23, 2019 Report Share Posted March 23, 2019 Ok so finally but the bullet and put a deposit on a 260 this morning. Been riding a 250T EXC for the last 3 years, mainly greenlaning and a Gasser TXT Pro before that. Want to carry on with the greenlaning so they are registering it for me, may do some local trials but intend to carry on using Wern Ddu as much as possible, but will be getting the taller seat and number plate fuel tank for a starter. So what else do I need to look out for and need to add? I’m not averse to a bit of bling and after reading just about the whole forum think i will get a better sump guard for a start. Over to you... 2 Quote Link to comment Share on other sites More sharing options...
steve0 Posted March 27, 2019 Author Report Share Posted March 27, 2019 Thanks for all the reply’s..... Maybe someone can help with this then, just picked up our kids 260 and it’s got this stand on it, anyone any idea what/where from? Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted March 28, 2019 Report Share Posted March 28, 2019 5 hours ago, steve0 said: Thanks for all the reply’s..... Maybe someone can help with this then, just picked up our kids 260 and it’s got this stand on it, anyone any idea what/where from? That's a Mitani kickstand. I have one on my 07 4RT and love it. That one doesn't look adjusted correctly as the foot should come up over the swing arm to prevent it from hanging down where it could get hit. Quote Link to comment Share on other sites More sharing options...
steve0 Posted March 28, 2019 Author Report Share Posted March 28, 2019 Thanks for that a great help, i see what you mean it looks as if it needs to swing out more to miss the axle nut. Quote Link to comment Share on other sites More sharing options...
sportsawyer Posted March 28, 2019 Report Share Posted March 28, 2019 19 hours ago, steve0 said: ... Another suggestion from the image above. You're at the end of snail cam adjustment, and from looking at the tensioner, you may need another notch (but can't tell for sure). No need to remove a link. There's another set of threaded snail cam stop screw holes aft of the current stop. It's under the cam now, but if you loosen things up and rotate the cam you'll see it. Move the stop screws, and you'll get back to the low end of the cam. That's a real bonus getting the Mitani sidestand. Much better than stock. 1 Quote Link to comment Share on other sites More sharing options...
steve0 Posted March 29, 2019 Author Report Share Posted March 29, 2019 Thanks great advice, will the slightly longer wheelbase have any tangible effect? Quote Link to comment Share on other sites More sharing options...
b40rt Posted March 30, 2019 Report Share Posted March 30, 2019 22 hours ago, steve0 said: Thanks great advice, will the slightly longer wheelbase have any tangible effect? Better grip. 1 Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted March 31, 2019 Report Share Posted March 31, 2019 On 3/29/2019 at 5:59 AM, steve0 said: Thanks great advice, will the slightly longer wheelbase have any tangible effect? I find longer wheel base will provide better grip in slick conditions and on rough ground. It dose change rear wheel hop timing a touch but I don't think most people would notice that much, and technically would make a bike turn a bit slower however again not sure how many people would really notice that. My 2 cents/experience. Hope it helps. 1 Quote Link to comment Share on other sites More sharing options...
jimmyl Posted April 1, 2019 Report Share Posted April 1, 2019 On 3/30/2019 at 10:56 AM, b40rt said: Better grip. I always thought shorter wheel base gave better grip as moved weight to the back - longer wheel base gave stability and kept front end down and hence the 52" or so compromise on the majority of trials bikes over the years. Quote Link to comment Share on other sites More sharing options...
b40rt Posted April 1, 2019 Report Share Posted April 1, 2019 1 hour ago, jimmyl said: I always thought shorter wheel base gave better grip as moved weight to the back - longer wheel base gave stability and kept front end down and hence the 52" or so compromise on the majority of trials bikes over the years. Moving the wheel back, without doing anything else, will make the suspension slightly softer. In my experience, longer wheelbase improves grip. (Look at hill climb bikes) 1 Quote Link to comment Share on other sites More sharing options...
steve0 Posted April 12, 2019 Author Report Share Posted April 12, 2019 And whoever it was who suggested this, you Sir are a gent and a scholar! Quote Link to comment Share on other sites More sharing options...
