Fantic Section fan/ thermostat problems
luke7129
Hi guys I have recently got hold of a 1995 Fantic Section 249r. It is not on the original engine because the previous owner will and truly ruined it so the new one is date stamped 94. After a few electrical problems I’ve finally got it running and the engine is sweet however I run it to see if the fans was working but it doesn’t seem to kick in. I’ve had the thermostat rethreaded into the top of the cylinder cos someone had ruined the threads. Is there anyway of testing the stat or fan to see if they actually work? Many thanks Luke
Easiest way to make sure the fan motor works is to join the 2 wires to the thermoswitch together, either use a short piece of wire with the correct spade teminals on the ends or just use a paperclip. I have the piece of wire in the bottom of my bag that is always with me on the bike to make sure if something does happen I can always ride back to my car especially when trail riding
When the motor is running the fan should work by doing this, if it doesn't then either your fan motor or 1 of the wires is faulty
  • 1 month later...
