4rt Dual Map Software
dmck_fantic
The P.N. 38771-NLC-000 is the HRC number used when the two-map system was first released. The later versions should work: 2008 RTL260F CD P.N. 38771-NN4-307, 2010 RTL260F CD P.N. 38771-NN4-H00.
I've installed the 38771-NN4-307 software on a Windows 7 32-bit computer. It will not install on Windows 7 64-bit computers. If you're using the USB Serial I/F wiring, you can update the Silicon Labs CP210x driver to work with your OS.
I've installed the 38771-NN4-H00 software on Windows 7 32-bit & 64-bit computers and a Windows 10 64-bit computer. The manual for this version only shows use with the USB wiring, you can update the Silicon Labs CP210x driver to work with your OS.
HRC Japan hasn't updated their compatibility chart online to show the 2010 software, but the 2008 software is backward compatible with TB/ECUs and can support either serial port of USB wiring. I'd think the 2010 software is also fully backward compatible with bikes, but not sure if it supports the old serial port wiring.
  • Thanks 2
