evo boy Posted March 31, 2019 Report Share Posted March 31, 2019 Wonder if anyone can help. My mate has a 2017 factory 300 and after 5/10 minutes of riding the fan cut in then will cut in and out every couple of minutes and the engine seems a bit fluffy and you seem to get a anti freeze smell. The day after the bikes been ridden if you undo the rad cap the pressure will blow it out of your hand if not careful. He has now changed the head gasket but still seems to be the same. Does anyone have any ideas. Many thanks Quote Link to comment Share on other sites More sharing options...
huski Posted March 31, 2019 Report Share Posted March 31, 2019 Id check the cylinder head O rings again,that's the only thing that would pressurise the rad to that degree.Does it have a pressure release valve in the top of the rad?if so sounds like it's faulty Quote Link to comment Share on other sites More sharing options...
evo boy Posted April 2, 2019 Author Report Share Posted April 2, 2019 On 3/31/2019 at 6:06 PM, huski said: Id check the cylinder head O rings again,that's the only thing that would pressurise the rad to that degree.Does it have a pressure release valve in the top of the rad?if so sounds like it's faulty Thanks for that Huski I'll check Many thanks Quote Link to comment Share on other sites More sharing options...
cascao Posted April 2, 2019 Report Share Posted April 2, 2019 If cylinder head is ok, check water flow (plastic pump rotor or plastic gear failture led to this pressure issue too) You can easly remove pump cover on right and see pump . Try spin it with you fingers Quote Link to comment Share on other sites More sharing options...
