guernseyrob Posted April 2, 2019 Report Share Posted April 2, 2019 I have just saved a beta zero not sure if it's a 91 or a 90 but the bike is almost complete but I can't find a coil or cdi unit anywhere and this is all that's missing for me to make it complete before I start a ground up resto on it, any help or advice would be much appreciated thanks in advance rob Quote Link to comment Share on other sites More sharing options...
guernseyrob Posted April 2, 2019 Author Report Share Posted April 2, 2019 also need a rear rim have the original hub and spokes Quote Link to comment Share on other sites More sharing options...
goudrons Posted April 3, 2019 Report Share Posted April 3, 2019 I'm pretty sure that's a 1991, I had one way back. They were either 240cc or 260cc. They weren't a bad bike back in the day, frame/tank was a bit unkind to your knackers if you got thrown forward and the water pump driveshaft wore/rusted up. Was a bugger to sort as there are lots seals and bearings for it and the cases need splitting to get at them all, as it picks up the drive from one side of the crankcases and goes right across the engine to the pump on the other. Another weak area was the swinging arm pivots, the voids where the bearings and bushes fit were quite thin and brittle and tended to snap across the top of the voids. As time wore on some of the other alloy parts got a bit brittle as well. The original rear rim was a flanged DID, I seem to think the same rim was fitted to the earlier Montesa 315r's. (later 315r's had similar flanged rim, but milled out in the gaps between the spokes, not sure one of those would lace up) Not sure if the Techno shared a CDi and coil with it, have you spoken with John Lampkin at Beta UK? Quote Link to comment Share on other sites More sharing options...
goudrons Posted April 3, 2019 Report Share Posted April 3, 2019 Here you go, these might help https://www.betausa.com/content/trial-model-history-0 http://trialsport.com.au/beta/Parts/Zero 91.pdf Quote Link to comment Share on other sites More sharing options...
reggie Posted April 3, 2019 Report Share Posted April 3, 2019 1991 there is no CDI box 1/2 of the CDI is in the stator and the other 1/2 is in the HT coil. Quote Link to comment Share on other sites More sharing options...
guernseyrob Posted April 4, 2019 Author Report Share Posted April 4, 2019 awesome thank you all very much for your help, now just have to try and locate a coil witch is proving painful Quote Link to comment Share on other sites More sharing options...
reggie Posted April 4, 2019 Report Share Posted April 4, 2019 I think part number HTC48 from rexs-speedshop may be the coil you are looking for. Let us all know if this turns out to be true. Quote Link to comment Share on other sites More sharing options...
guernseyrob Posted April 4, 2019 Author Report Share Posted April 4, 2019 thank you very much Reggie I have contacted rexs will let you know how this turns out, I appreciate your help very much Quote Link to comment Share on other sites More sharing options...
