hgas Posted April 4, 2019 Report Share Posted April 4, 2019 Hi just bought my first evo and I’m after some advice , first question ,clutch and brake levers -do I have to buy ones specifically for the grimeca master cylinders or are all levers universal now ? Secondly how much gearbox oil do I put in on service and what oil are people using , last one the stickers are coming away in places (common beta problem I’m told) anyone had any luck with sticking them back down ? Thanks in advance guys ? Quote Link to comment Share on other sites More sharing options...
pindie Posted April 4, 2019 Report Share Posted April 4, 2019 (edited) Levers for the MCs are easily available on you tube. Short ones are nice, I had some Apico cold forged ones- excellent. Bendy ones not needed. 500ml of Nano Trans GP. No drag. Neutral easy. Last ages. Two changes from one bottle. Stickers = Super glue. Watch your fingers! Edited April 4, 2019 by pindie Quote Link to comment Share on other sites More sharing options...
peter_steer Posted April 4, 2019 Report Share Posted April 4, 2019 I have had good results sticking down stickers with spray adhesive, the type used for sticking down vinyl and carpets, you can get it from the major builders merchants for £3.99 If its just the corners, spray some into a lid and then use a cotton bud to apply it to one side, wait 30 seconds, then press down. Any excess can be cleaned with a bit of brake cleaner on a cloth. If its really hanging off, peel it off, clean it up with brake cleaner or similar, ( and clean the surface its being stuck to ), spray the whole sticker, wait 30 seconds and refit. Good luck Quote Link to comment Share on other sites More sharing options...
hgas Posted April 5, 2019 Author Report Share Posted April 5, 2019 Ok thanks for that chaps ! Next questions , the bike is a standard 2016 300 evo , I’ve noticed it’s ‘running on’ abit , do they come with a flywheel weight fitted as standard and can it be removed?also what jetting are people running ? I think the carb needs a good sort out to get it running better Quote Link to comment Share on other sites More sharing options...
