Beta Front Forks
jsyben94
Hi all
Looking to stiffen up my front forks on my 19 Factory, does anyone  know of where I could get hold of a stiffer spring ?
The aftermarket one is out of stock everywhere and apparently there isn’t anyone making them.
Also would using thicker oil help if so what weight could I go up to ?
Thanks in advance for your help !
Edited by jsyben94
12 minutes ago, lineaway said:
 You got to be pretty big to need stiffer front. So did you already get a heavier rear?
Possibly the world biggest trials rider 6 ft 8”, 17 stone.
Already got a stiffer spring on the rear already but still find it too soft, just ordered an Ohlins set up for my size.
  • Thanks 1
I’ve just rebuilt my front forks with new fork seals , I’m now finding the forks very soft they don’t bottom out but they’re not far off ,I’ve used belray 7.5 and I followed the guide of 60 ml air gap in the damper side and 120 spring side , my question is can I just unscrew the top caps and add more oil to stiffen them up?
