Rodneymcalpin
Rodneymcalpin
It seams to go to to first but if i tap the shiftier after I start moving it will some times seam to click again. I assumed it is backing partially out of gear and then after the tap it returns. All of the other gears work so I don't think it is out of adjustment. I think the detent spring and ball are worn and maybe a spring spacer on it may help. Any one have other ideas?
