Kdtx240 Posted July 31, 2022 Author Report Share Posted July 31, 2022 (edited) put new condensor - used 12v from a nissan car - it looked the same. I earthed the condenser to the coil and got all my wires going to the coil and soldered the whole bunch together. I removed the flywheel and disconnected the old condenser isolated it and got all the wires that were connected to it and soldered the whole lot together. I gapped and cleaned the points the old condenser was not bad and this helped the bike marginally. I can rule out the ignition now - the bike was supplied with a working ignition and it was. my carb is a phbh26PS I dont think Eurocarb lists this particular model to get the specs from. Standard Jetting for a phbh26 bs 40 Slide X7 Needle 266AV Atomiser 110 Main jet 50 Idle jet 70 Choke jet 200 Float valve 9010.2 Float – 6.5 grams My Carb is completely different I think the slide is stamped 110 or 90 or something wonder should i just get a working carb off a swm 280. trying to tune a carb that the maker does not list seems like a lot of faffing around. then again fitting an X7 needle might solve the problem its the needle jet at fault the bike wont rev high but you could lug it about all day I am also confused where this main jet is - i thought there was usually 3 jets in a carb pilot jet needle jet and choke jet? Edited July 31, 2022 by Kdtx240 Quote Link to comment Share on other sites More sharing options...
Kdtx240 Posted July 31, 2022 Author Report Share Posted July 31, 2022 i am actually wrong my main jet is 88 slide is 50 atomiser is av266 bn264 came originally. original needle is lost my carb is off a 240cc so 280 is much bigger and needs more fuel float jet is 200 float needle looks good and i put new white "floats" in the bike could actually be lean bogging and creating a black plug as it never gets cleared out making it look like rich I am going to go with an X7 needle and 110 main jet check float height and take it from there Quote Link to comment Share on other sites More sharing options...
dozerash Posted August 24, 2022 Report Share Posted August 24, 2022 (edited) I had a Montesa 349 that I mounted the condenser on the frame under the tank to keep it cooler. On my SWM I used a timing box I made to set points. I have since switched the ignition to electronic (about 3 or 4 years ago). I bought the kit from MotoSWM, works awesome! I switched my carb to a OKO from MidAtlantic trials, that also works awesome! They do make a OKO kit for the 240 Rotax. Edited August 24, 2022 by dozerash Quote Link to comment Share on other sites More sharing options...
Kdtx240 Posted September 15, 2022 Author Report Share Posted September 15, 2022 Hi all moved the bike to another shed and the float valve dropped out - had to buy another one of those before anything happened. fitted the 110 jet slight improvement - adjusted the needle as far as it could go plan is to fit 120 jet and see if it gets better. if not then 125 or 130 jet. I do think it is a fuelling issue that will be fixed by a bigger main jet and have one on order. funny I was recommended an electronic ignition but they are expensive, luckily my points is good and I have a backup stator/ignition. - I fitted one to a cr250 because I had no other choice- the cdi's die and replacements are rare as hens teeth - was not impressed with the fit of the pickup to the flywheel despite a lot of tinkering, I cant remember the clearance I got but it was a very small feeler gauge. it did start. I am bringing this bike back home to finish and am quite excited I done all the linkage bushes on this one and it should be very tight and the engine is good. good to talk to you all again. 👍 Quote Link to comment Share on other sites More sharing options...
