ENGLISHBANDIT Posted April 27, 2019 Report Share Posted April 27, 2019 (edited) Hi everyone Just a quick question. whats the best engine oil to use in these beta evo 300 bikes. I just picked up some Putoline light gear 75W for now. but is there any better stuff that everyone uses.I will be doing the oil change every 5 hours no matter what. thanks in advance Edited April 27, 2019 by ENGLISHBANDIT Quote Link to comment Share on other sites More sharing options...
totty79 Posted April 27, 2019 Report Share Posted April 27, 2019 The gearbox oil has a fairly easy life, changing it that frequently is a waste. On the Beta oil choice is mainly about minimising clutch drag, you may get away with what you've bought or you may need either nanotrans or motul 300v. Quote Link to comment Share on other sites More sharing options...
ENGLISHBANDIT Posted April 27, 2019 Author Report Share Posted April 27, 2019 Thanks for info. Quote Link to comment Share on other sites More sharing options...
pjw123 Posted April 27, 2019 Report Share Posted April 27, 2019 Beta UK recommended 75w light gear oil. That's the answer I got when I called them. Know a few people who have messed about with clutch action / plates. etc ,etc. I 've never had any bother. Change oil every 4 or 5 trials, not hours. Its generally pretty clean. Quote Link to comment Share on other sites More sharing options...
ENGLISHBANDIT Posted April 27, 2019 Author Report Share Posted April 27, 2019 Top man that’s what I was given at a trials shop Putoline light gear 75w Quote Link to comment Share on other sites More sharing options...
lineaway Posted April 27, 2019 Report Share Posted April 27, 2019 If you want the clutch to actually hit, use ATF. Been that way now for three decades of Beta`s. Quote Link to comment Share on other sites More sharing options...
MIckyT Posted April 28, 2019 Report Share Posted April 28, 2019 ELF HTX works fantastic in Betas a bit more expensive but also last a lot longer. 1 Quote Link to comment Share on other sites More sharing options...
ahh_me2 Posted April 28, 2019 Report Share Posted April 28, 2019 19 hours ago, lineaway said: If you want the clutch to actually hit, use ATF. Been that way now for three decades of Beta`s. My question is , does it matter which ATF? Is there a preferred ATF brand? I have an older Beta Rev3 250 2001 and would like to change the oil, but I see too many choices of ATF on the shelves, so I really don't know what to buy Quote Link to comment Share on other sites More sharing options...
lineaway Posted April 28, 2019 Report Share Posted April 28, 2019 Dexron iii or type F. I had three 2001`s in `01. All ran ATF. Loved that Blue. Quote Link to comment Share on other sites More sharing options...
ahh_me2 Posted April 28, 2019 Report Share Posted April 28, 2019 Thanks lineaway! Quote Link to comment Share on other sites More sharing options...
ENGLISHBANDIT Posted April 28, 2019 Author Report Share Posted April 28, 2019 I have done an oil change today and used 75W light gear oil. See how that goes. I remember 2 years ago using 4 stroke oil in my sherco 290 recommended by a good trials shop ?. To be honest starting to think to many bloody choices ?. Simple with my road bikes. Anyway lads thanks for in put. But guess oil is just like bike tyres, everyone has an opinion on what’s best but guess it’s just down to what you like or trust. Thanks again Quote Link to comment Share on other sites More sharing options...
mightychub Posted June 17, 2019 Report Share Posted June 17, 2019 I have been using rock oil since getting my 17 factory and it has worked great but I now have a local supplier for Putoline so once I have used up what I have am switching to what my local Beta shop recommend as I think it works slightly better for the clutch Quote Link to comment Share on other sites More sharing options...
markbxr400 Posted June 22, 2019 Report Share Posted June 22, 2019 On 4/28/2019 at 5:55 AM, MIckyT said: ELF HTX works fantastic in Betas a bit more expensive but also last a lot longer. I run this in both my Montesa's. Only because I have to. Darned expensive ($50/qt) and takes a coupe of weeks to get it here in the US. Much cheaper options are available for the Beta, eg,, Lineaway's suggestion. Also, should be no problem going 30 hours between changes. Quote Link to comment Share on other sites More sharing options...
chaser Posted June 23, 2019 Report Share Posted June 23, 2019 2 2 Quote Link to comment Share on other sites More sharing options...
