mudyman Posted May 4, 2019 Report Share Posted May 4, 2019 Hi all, I have a silver engine RL250 thats using a 72 mm Wiesco piston and now needs a new little end bearing. I became all the Wiesco numbers for Piston Rings piston pin and clips from the last owner but not for the small end baering. Wiesco don´t seem to have any idea what bearing is needed so I thought I´d give it a try here :-) Quote Link to comment Share on other sites More sharing options...
Bilko Posted May 4, 2019 Report Share Posted May 4, 2019 Have you tried here http://www.beamishownersclub.com/ Quote Link to comment Share on other sites More sharing options...
shakennstirred Posted May 4, 2019 Report Share Posted May 4, 2019 https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F271155266283 Quote Link to comment Share on other sites More sharing options...
Rhoda_Sodapop Posted January 23, 2021 Report Share Posted January 23, 2021 On 5/4/2019 at 1:23 PM, mudyman said: Hi all, I have a silver engine RL250 thats using a 72 mm Wiesco piston and now needs a new little end bearing. I became all the Wiesco numbers for Piston Rings piston pin and clips from the last owner but not for the small end baering. Wiesco don´t seem to have any idea what bearing is needed so I thought I´d give it a try here ? Small end bearing should be 18x23x24 but best place to check is with Crooks Suzuki in Barrow in Furness. Quote Link to comment Share on other sites More sharing options...
mudyman Posted March 6, 2021 Author Report Share Posted March 6, 2021 Hi Rhoda, "sorry" didn´t read this until today 😞 I´ll give you a line when the Jumbo clutch cable and badges have arrived Ian Quote Link to comment Share on other sites More sharing options...
