Johnny Reggie Posted May 6, 2019 Report Share Posted May 6, 2019 Hi, I wonder what the forum's thoughts are on maintenance. I have just bought a late 2016 4RT which has clearly had next to no use. The seller reckoned that it has been used for no more than 3 or 4 hours. Gauging by its good nick, tyres, paint, wheels, casings I think so. Certainly never been trialled and looks like it's been stored in a dry place. The manual talks hours and annual/bi-annual checks and works. I have changed engine oil and filter (was Honda OEM and probably this is its first service), gear Oil, plug and air filter. Given its age and not its use should I be doing anything else or am I good to go? Runs and starts fine. All thoughts appreciated.... Cheers, Reg Quote Link to comment Share on other sites More sharing options...
jimmyl Posted May 6, 2019 Report Share Posted May 6, 2019 Sounds like you are good to go and got yourself a bargain. there are a few mods if you are doing serious trialing but if just for general riding good to go Quote Link to comment Share on other sites More sharing options...
Johnny Reggie Posted May 6, 2019 Author Report Share Posted May 6, 2019 7 minutes ago, jimmyl said: Sounds like you are good to go and got yourself a bargain. there are a few mods if you are doing serious trialing but if just for general riding good to go Thanks Jimmyl, that's what I hoped to hear! I am going to compete, after years away, but don't expect to be setting the world on fire. I've got a Mitani bash plate coming (went for the 5mm as opposed to 6 as I'm not going to be doing anything really heavy duty), Mitani stand and that's it so far. I have thought about the air filter protection and the bike has the std splash guard under the rear mudguard and I think this should be ok...I'm in the south and it's not like there are the rocks and streams that you regularly ride up North. Cheers Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted May 6, 2019 Report Share Posted May 6, 2019 Just check that nuts and bolts are not loosening off. 1 Quote Link to comment Share on other sites More sharing options...
Johnny Reggie Posted May 6, 2019 Author Report Share Posted May 6, 2019 Thanks 2stroke4stroke, I'll do that. Got myself a case saver too.. Ready for off... Quote Link to comment Share on other sites More sharing options...
jimmyl Posted May 6, 2019 Report Share Posted May 6, 2019 would put the mesh on the mudguard vents and dump the oil catch tray under the head stock Quote Link to comment Share on other sites More sharing options...
Johnny Reggie Posted May 6, 2019 Author Report Share Posted May 6, 2019 4 minutes ago, jimmyl said: would put the mesh on the mudguard vents and dump the oil catch tray under the head stock Cheers. I had seen a couple with mesh under the vents (in the dip of the "seat area" right?) and wondered 'cos you can see the electrical connectors and what not - is it just a mesh and tape job?? Where's the oil catch tray under head stock Jimmy - can't see anything that looks remotely like an oil catch tray... Sorry about the dumb questions, my first 4RT! Quote Link to comment Share on other sites More sharing options...
thall1 Posted May 6, 2019 Report Share Posted May 6, 2019 if you remove the tank and look into the gap left the catch tank is tucked up behind the head stock Quote Link to comment Share on other sites More sharing options...
Johnny Reggie Posted May 6, 2019 Author Report Share Posted May 6, 2019 And is it that it serves no purpose, or? Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted May 7, 2019 Report Share Posted May 7, 2019 I just taped up the vents from the inside. Bike runs fine and the amount of muck that still reaches the filter shows that plenty air is getting through. Quote Link to comment Share on other sites More sharing options...
Rollox Posted May 7, 2019 Report Share Posted May 7, 2019 I just put a little strainer on the air intake. 2 Quote Link to comment Share on other sites More sharing options...
Johnny Reggie Posted May 7, 2019 Author Report Share Posted May 7, 2019 1 hour ago, rollox said: I just put a little strainer on the air intake. Tea strainer... like it! Cheers Quote Link to comment Share on other sites More sharing options...
Johnny Reggie Posted May 7, 2019 Author Report Share Posted May 7, 2019 2 hours ago, 2stroke4stroke said: I just taped up the vents from the inside. Bike runs fine and the amount of muck that still reaches the filter shows that plenty air is getting through. Ahhh that helps. So no worries about the gauge of mesh then. Thanks a lot ? Quote Link to comment Share on other sites More sharing options...
Johnny Reggie Posted May 7, 2019 Author Report Share Posted May 7, 2019 13 hours ago, thall1 said: if you remove the tank and look into the gap left the catch tank is tucked up behind the head stock Thanks thall1. Ive had the tank off and can see the white plastic tank. Looks like there are pipes connected, haven't had a real close look yet, will do that later. I'm intrigued as to what is to be gained by dumping it as jimmyl suggested... Quote Link to comment Share on other sites More sharing options...
jimmyl Posted May 7, 2019 Report Share Posted May 7, 2019 Hi - if you search the forums will be in more detail but basically I think its an emission thing or environment thing. If you dump the tank you can blanks off the hole in the air box which stops any excess oil gathering in ther. Also the fan relay mounted below the Throttle Body can now be placed up out of harms way behind the head stock where the little tank came from. I then put a small in line fuel filter on the end of the pipe from the engine to the now removed tank and again tuck up in the head stock. The tank and pipe to airbox can now be stored away until you sell the bike and present the new owner with a box of bits he is never going to use again either ? Worth getting one of the little button fuel cap breathers and dumping all the vents and pipes that come as standard - get the flush fit ones. Honda genuine bits can be good value so don't be afraid to look there first. 315r bits are also common/interchangeable ie swing arm/linkage wheels etc 1 Quote Link to comment Share on other sites More sharing options...
