detective 21 Posted May 16, 2019 Report Share Posted May 16, 2019 (edited) does anyone have one of these or photos of one, I have managed to get hold of a frame for a build and am looking for info around the frames? any input appreciated Edited May 26, 2019 by detective 21 picture upload Quote Link to comment Share on other sites More sharing options...
detective 21 Posted May 26, 2019 Author Report Share Posted May 26, 2019 photos now added Quote Link to comment Share on other sites More sharing options...
trialsrfun Posted May 27, 2019 Report Share Posted May 27, 2019 On 5/16/2019 at 6:49 PM, detective 21 said: does anyone have one of these or photos of one, I have managed to get hold of a frame for a build and am looking for info around the frames? any input appreciated Expand Do the pictures show the bike you have? Quote Link to comment Share on other sites More sharing options...
detective 21 Posted May 27, 2019 Author Report Share Posted May 27, 2019 yes, doing the dry build to see how everything will work together at the moment Quote Link to comment Share on other sites More sharing options...
trialsrfun Posted June 2, 2019 Report Share Posted June 2, 2019 On 5/27/2019 at 5:22 PM, detective 21 said: yes, doing the dry build to see how everything will work together at the moment Expand It is looking good already, what engine set up will it be 199cc, also are you staying with the Montesa forks? Quote Link to comment Share on other sites More sharing options...
detective 21 Posted June 3, 2019 Author Report Share Posted June 3, 2019 On 6/2/2019 at 9:26 PM, trialsrfun said: It is looking good already, what engine set up will it be 199cc, also are you staying with the Montesa forks? Expand at the moment I am staying with the monty forks, may change the yokes though a there appears to be a couple degrees rake in them but will see how it rides first, the engine is a pretty standard set up, dellorto carb, electrixworld ignition, standard clutch with alloy pressure plate, gearing- 16 engine/ 13 gearbox/ 62 sprocket, it weighs 77kg currently with no fuel or engine oil. Quote Link to comment Share on other sites More sharing options...
