Craigop Posted May 18, 2019 Report Share Posted May 18, 2019 Hi, recently bought a 2001 gasgas 280txt as bait if a project. Will start but doesn't run very well or rev very high and doesn't run for long before exhaust is glowing red hot. Have stripped and cleaned carb and air filter. Any ideas what it could be?? Thanks Quote Link to comment Share on other sites More sharing options...
feetupfun Posted May 18, 2019 Report Share Posted May 18, 2019 A very hot exhaust header and poor running can be caused by the ignition timing being set too late Quote Link to comment Share on other sites More sharing options...
Craigop Posted May 18, 2019 Author Report Share Posted May 18, 2019 Thanks. Flywheel off and adjust is it? Easy todo? Cheers Quote Link to comment Share on other sites More sharing options...
b40rt Posted May 18, 2019 Report Share Posted May 18, 2019 Check woodruff key is present and correct. Look for tell tail marks on the back plate indicating its been move, or original position. 1 Quote Link to comment Share on other sites More sharing options...
Craigop Posted May 18, 2019 Author Report Share Posted May 18, 2019 Will check this later this afternoon thanks Quote Link to comment Share on other sites More sharing options...
misscrabstick Posted May 18, 2019 Report Share Posted May 18, 2019 Lean mixture or retarded timing, probable the flywheel key has sheared and retarded the ignition timing because the flywheel has moved around the crankshaft. Quote Link to comment Share on other sites More sharing options...
d2w Posted May 18, 2019 Report Share Posted May 18, 2019 (edited) This is a pretty basic one ... and it's somewhat speculative on my part ... but could a partially plugged exhaust system account for the symptoms? Perhaps the exhaust gasses are not exiting the pipe well enough? Has somethings plugged and/or restricted the exhaust? Edited May 18, 2019 by d2w Quote Link to comment Share on other sites More sharing options...
Craigop Posted May 18, 2019 Author Report Share Posted May 18, 2019 Woodruff key had gone, thanks all. New one ordered, hopefully be runny fine in few days thanks 1 Quote Link to comment Share on other sites More sharing options...
thai-ty Posted June 19, 2019 Report Share Posted June 19, 2019 On 5/18/2019 at 9:04 PM, d2w said: This is a pretty basic one ... and it's somewhat speculative on my part ... but could a partially plugged exhaust system account for the symptoms? Perhaps the exhaust gasses are not exiting the pipe well enough? Has somethings plugged and/or restricted the exhaust? Concur. I'd check this as well. Quote Link to comment Share on other sites More sharing options...
