Martin21 Posted May 20, 2019 Report Share Posted May 20, 2019 Hi I'm new on hear I'm just woundring if any of u could tell me why my bike won't start cold but will fine when warm cheers martin Quote Link to comment Share on other sites More sharing options...
lineaway Posted May 20, 2019 Report Share Posted May 20, 2019 Clean the carb. Most likely a plugged up pilot jet. 1 Quote Link to comment Share on other sites More sharing options...
Flooky Posted May 24, 2019 Report Share Posted May 24, 2019 I had this, took ages and loads of kicks to start , then it would run fine all day, turned out to be in line fuel filter. I think once it had a flow it was fine but wouldn't pull fuel through. It looked clean but I cut it open to see after fitting a new one and it was partially blocked. 2014 sherco 250 st Quote Link to comment Share on other sites More sharing options...
knobbly Posted May 24, 2019 Report Share Posted May 24, 2019 Assuming that fuel tap / carb filter / starter jet is not blocked.............Mine was difficult during the cold weather, so I tipped it right over to the the left for a few seconds to flood before kicking. That certainly helped. If you still struggle, try a #70 to replace the #60. They are cheap and will get more fuel through. Quote Link to comment Share on other sites More sharing options...
Martin21 Posted May 24, 2019 Author Report Share Posted May 24, 2019 Cheers for the replys took carb off cleaned it all with carb cleaner blew it out with compresser put it back on and seems to have done the trick up to now ? Quote Link to comment Share on other sites More sharing options...
brianrch Posted May 25, 2019 Report Share Posted May 25, 2019 I have found with my 2015 (still rear tank with fuel pump) that if it sits for a time and colder weather that it would be difficult to start but if I placed the fuel on reserve it starts 2nd kick. In the past if I didn't run it for a few weeks in Winter it would take 8-10 kicks but by doing this it is 2nd kick every time. Quote Link to comment Share on other sites More sharing options...
