Gas Gas Txt Racing 125 2015 weak spark and cutting out
sw74gls
Gas Gas Txt Racing 125 2015 weak spark and cutting out - Hi Guys could some one please give me some advice on the specific values on the Stator Plate, Coil, Pickup etc I cannot find a Diagram for this Model nor the gas gas Workshop/Technician Manual ( the one you can normally buy) so im stuck as I have done various testing but have no Values to compare to?
Basically I got the bike with low compression and dirty carb etc I cleaned carb it started after a few kicks but once warm became hard to start? I changed piston rings which improved compression greatly, but then became even harder to start and then once warm would just simply cut out and not restart until cold. when you turn the engine over it doesnt spark unless you turn it very fast and even then it misses 2 out of 3 revolutions, producing a very faint spark, nothing like any other gas gas ive owned.?
I would really appreciate your help please guys.
