Ring Gap
neilfrancis
I'm sure my old man used to quote so many thou per inch of bore.  Had a quick google and turned up similar on Wisecos website
  Quote
Once the piston ring is located and squared up, measure the end gap using the feeler gage. A rule of thumb for ring end gap measurement is to use the bore size in inches x .005”. In the example here, a KTM150, the bore is 56mm (56 divided by 25.4 = 2.2047”). If you multiply 2.2047” x .005”, the result is .011”. This would be the minimum installed ring end gap. A typical high measurement for the piston ring end gap would be the bore in inches x .007” (2.2047 x .007” = .015”). These calculations are a general guideline, and your OEM service manual will also provide further detail.
Expand
If anyone has a manual it might specify a certain value but the above would be a good starting point I would say.
