Ossa TR 80 Yellow 350 Gripper workshop manual.
chappo
I’ve just purchased a Gripper and was wondering if they ever did a Workshop Manual for it, or are all the 350 engines the same bar the fact there’s no Cush drive on the mine.
Also seem unable to source a piston at the moment, not taken the barrel off yet so not sure what size I need at present. Anybody got any out there?
Thanks.
Not sure there was a workshop manual but there is a parts list that you can download from various free download sites on the net. For engine strip, the engine components and layout are the same as the MAR apart from small updates over the years to gear selector shaft and layshaft bearings which went from bushes to needle rollers. This means you can't swap the gear train from a 'bushed' gearbox to a roller gearbox and vice-versa. They look identical but there are small differences in shaft lengths and diameter. The Gripper has the clutch weight that the MAR doesn't have
They have a cush drive, it's behind the clutch crank weight
Pistons are very hard to get, you'll probably have to trawl the specialists in Spain or USA, I don't know of any here. The 350 MAR uses the same piston but the pins are in a different location from the Gripper so there may be issues with them fouling in the ports. I guess they could be relocated. But the 350 MAR piston is probably equally hard to find
  • Thanks 1
