scatman Posted June 5, 2019 Report Share Posted June 5, 2019 Hi, Info required please....The owner's manual says 700cc of 10W40 but I have read on here 450cc of 80wt light gear oil. I prefer gear oil but could someone please clarify the correct quantity and viscosity. Here's hoping ☺️ Quote Link to comment Share on other sites More sharing options...
heffergm Posted June 5, 2019 Report Share Posted June 5, 2019 (edited) The manual is correct. 2017+ models with diaphram clutches all take ~700mL. The fill plug doubles as an inspection hole, so you could always just stuff it as full as you can then whatever runs out was extra, with the bike level on its tires. You could use 10w40 motor oil, but most folks use 75w gear oil (Maxima MTL, Silkolene Gear Oil Light, etc.) Edited June 5, 2019 by heffergm Quote Link to comment Share on other sites More sharing options...
trev125 Posted June 5, 2019 Report Share Posted June 5, 2019 (edited) RYP recommends 75wt gear oil. I have been using it with good results. Edited June 5, 2019 by trev125 Quote Link to comment Share on other sites More sharing options...
thesolidman1 Posted June 5, 2019 Report Share Posted June 5, 2019 I measured what came out of my new 2019, it was approx. 575 cc. Manual is wrong. Quote Link to comment Share on other sites More sharing options...
scatman Posted June 6, 2019 Author Report Share Posted June 6, 2019 Thanks for the replies...... I took the filler plug out the other night and oil started coming out, am I correct in assuming that it's overfilled and I need to drain some out? Thanks again.... Quote Link to comment Share on other sites More sharing options...
heffergm Posted June 6, 2019 Report Share Posted June 6, 2019 https://youtu.be/jssHZvtvcmg?t=13 Quote Link to comment Share on other sites More sharing options...
scatman Posted June 6, 2019 Author Report Share Posted June 6, 2019 Oil changed, old oil replaced with 700 ml of Maxima 75wt.....☺️ Quote Link to comment Share on other sites More sharing options...
scatman Posted June 6, 2019 Author Report Share Posted June 6, 2019 Many thanks for all the advice! Quote Link to comment Share on other sites More sharing options...
Tatx Posted September 16, 2024 Report Share Posted September 16, 2024 On 6/5/2019 at 8:47 PM, scatman said: Hi, Info required please....The owner's manual says 700cc of 10W40 but I have read on here 450cc of 80wt light gear oil. I prefer gear oil but could someone please clarify the correct quantity and viscosity. Here's hoping ☺️ Hi I have the same bike but I can't find the owners manual of the 2017 model, there is only the spare parts. Which manual do you have? I can find on the internet and sherco web the owners manuals of models 2016 and 2018 but I need 2017. Where can I find? Thank you. Quote Link to comment Share on other sites More sharing options...
