jmutiger Posted June 11, 2019 Report Share Posted June 11, 2019 I've finally kinked up my throttle cable enough to need to replace it. Any tips before I start? I have an oem cable to go into it. Thanks Jon Quote Link to comment Share on other sites More sharing options...
jimmyl Posted June 14, 2019 Report Share Posted June 14, 2019 From memory It's a mudguard off, loosen air box Unscrew the clamps on the inlet and air box hose -the throttle body will them come off if you unplug it. Tank off or at least unbolted Take plastic cover . Unclip Throttle end You can then twist the adjuster out of the Throttle body by spinning the throttle body - feed old cable out/ new cable back in Reverse above make sure you have free play in the cable. Also worth giving the throttle body a clean out - I used WD40 or similar to swill the internal bore - take out tick over screw and flush drilling - makes a note of the number of turns and don't loose the spring. 1 Quote Link to comment Share on other sites More sharing options...
steve0 Posted June 17, 2019 Report Share Posted June 17, 2019 Spot on Quote Link to comment Share on other sites More sharing options...
jmutiger Posted June 19, 2019 Author Report Share Posted June 19, 2019 Well I got it done and it was a pain in my butt! The throttle body was indeed dirty inside, and I think some of that was from the hose that comes from the head, and some normal combustion back flow mess. It wasn't bad but I didn't expect it to be dirty at all. Check your vent tube to make sure it's not letting unfiltered air in. Thanks for the tips, and if you do undertake this seemingly easy task give yourself at least 2hrs unless you've done it before. I did mine before riding which probably wasn't the smart thing to do. Jon Quote Link to comment Share on other sites More sharing options...
