b40rt Posted June 19, 2019 Report Share Posted June 19, 2019 (edited) Any cleaver person out there know if an NGK BPR5E is available in short reach ( ie12mm ) Thanks BPR5HS looks correct ? Edited June 19, 2019 by b40rt Quote Link to comment Share on other sites More sharing options...
moleman Posted June 19, 2019 Report Share Posted June 19, 2019 Change the E to H= BPR5H Quote Link to comment Share on other sites More sharing options...
b40rt Posted June 19, 2019 Author Report Share Posted June 19, 2019 1 minute ago, moleman said: Change the E to H= BPR5H Hi Craig, think the "S" only refers to the core being copper ? Quote Link to comment Share on other sites More sharing options...
moleman Posted June 19, 2019 Report Share Posted June 19, 2019 Used to , probably still does , time moves on . i would lose the R ( resistor ) and try a plug with an iridium or whatever is fashionable now centre electrode if it’s going on something with older ignition . Quote Link to comment Share on other sites More sharing options...
moleman Posted June 19, 2019 Report Share Posted June 19, 2019 If you do a plug chop , don’t use a cleaver! ( first post ) Does what it’s going in have a very good ignition system ? Quote Link to comment Share on other sites More sharing options...
tony27 Posted June 19, 2019 Report Share Posted June 19, 2019 E=3/4 reach, H=1/2 reach. S is standard electrode ie. the fat type, different last letter refers to shape of the electrode tip 1 Quote Link to comment Share on other sites More sharing options...
dabba Posted June 19, 2019 Report Share Posted June 19, 2019 This should help: 2 2 Quote Link to comment Share on other sites More sharing options...
lineaway Posted June 20, 2019 Report Share Posted June 20, 2019 17 hours ago, b40rt said: Any cleaver person out there know if an NGK BPR5E is available in short reach ( ie12mm ) Thanks BPR5HS looks correct ? Yes but the top will hit the tank. LOL Quote Link to comment Share on other sites More sharing options...
