whitehawk175 Posted June 24, 2019 Report Share Posted June 24, 2019 Hi All Would anyone know what was used for the headgasket on the 320 Majesty's. Quote Link to comment Share on other sites More sharing options...
majesty Posted June 25, 2019 Report Share Posted June 25, 2019 Just the same as the TY250 copper gasket, but slightly bigger bore. Not sure if they are still available, but you should be able to open out a 250 gasket with a dremel and a steady hand http://www.yamaha-majesty.com/?product=cylinder-head-gasket Quote Link to comment Share on other sites More sharing options...
majesty Posted June 25, 2019 Report Share Posted June 25, 2019 OEM Yamaha part number is 46Y-11181-00-00 Quote Link to comment Share on other sites More sharing options...
b40rt Posted June 25, 2019 Report Share Posted June 25, 2019 Try. https://www.tytrials.co.uk/contactus.html Quote Link to comment Share on other sites More sharing options...
whitehawk175 Posted June 25, 2019 Author Report Share Posted June 25, 2019 Quote Thanks to you all. Thought there may have been alternative, when opening the gasket up it leaves the sealing area quite narrow. Quote Link to comment Share on other sites More sharing options...
