Tomsmith1992 Posted June 28, 2019 Report Share Posted June 28, 2019 Hi all Going to look at a 2017 300 beta factory tomorrow, looking at the pictures it all looks tidy and well looked after. The only thing putting me off is the forks have excessive wear on the stations, they are meant to be black but bottom couple of inches are all rubbed down to silver. Is this a sign of excessive use or is it normal to have so much wear after 2 years? Just wondering as if it is excessive wear this will mean it will be a very high hours bike and may have other issues going forward? Any thoughts appreciated Cheers Quote Link to comment Share on other sites More sharing options...
huski Posted June 29, 2019 Report Share Posted June 29, 2019 It's done a lot to wear the black off .Id look for another bike Quote Link to comment Share on other sites More sharing options...
pjw123 Posted June 29, 2019 Report Share Posted June 29, 2019 It's clear evidence that it has very likely done a lot of work. 300 Factory is for Expert riders. Earlier models for some reason are OK, but later models in particular seem more prone to wear. (Cost cutting maybe??). Doesn't look that good & will always put buyers off. (If you buy it, you too will one day become the seller !!!..) Seals probably OK. You can get them re coated but not cheap. Worth noting for the future that application bit of light oil externally, lubricates seals & reduces wear rate of coating, Also, coatings on Alloy stanchions used by other makers tend to wear more quickly than coatings on steel stanchions. Quote Link to comment Share on other sites More sharing options...
hgas Posted June 29, 2019 Report Share Posted June 29, 2019 It doesn’t neccesarily mean that the bikes been well used , this is a big problem with betas , I’ve seen 2018 models that haven’t done a lot and this has started happening , look for other signs of usage, check underneath the sump guard see what that’s like , make sure you listen to the bike for any rattles or knocks .also have a good look at the front pipe you’ll know if it’s been well ridden if it’s covered in dents and scratches as this is a tell tale sign on the evos, good luck ! 1 Quote Link to comment Share on other sites More sharing options...
Tomsmith1992 Posted June 29, 2019 Author Report Share Posted June 29, 2019 Cheers all for your help. Picked it up today and all seems fine. Its only one statntion where the coating has worn off and this had a broken seal so I think grit must have got in top seal and hastened the wearing? All else looks fine but give it a real test tomorrow! 1 Quote Link to comment Share on other sites More sharing options...
