no clutch
vectradam
hi
my 2018 trs 280 has no clutch. there is only a little fluid in the master cylinder. I assume the seals must have gone in the slave cylinder.  Is this an easy job or could it be something else ?
many thanks
You just need to remove the clutch inspection cover not the full clutch case so the water pump stays in place.
I think the seals are just o rings, easy to fit, be careful not to drop the washer and thrust bearing that are on the underside of the case and sit on the slave cylinder.
Remember it's mineral oil not dot4
You can see all of the parts if you look at the parts diagram on TRS UK site
Edited by baldilocks
