This is repaired. Pin on CDI box supposed to be bent? 2005 Gas Gas TXT Pro
thesaint
I was checking the spark on my 2005 Gas Gas TXT 125 Pro when i noticed that 2 wires on the connector for the CDI box on the stator harness was almost broken off.
The wires was only hanging by 1 single strand in the wire each so that explains that i did not have a spark at each stroke of the kick panel
I replaced the 2 broken wires with new ones that have the "end pin" that goes down inside the stator harness connector for the CDI box
But when i looked inside the "connector" on the CDI box i can see that one of the "pins" is bent so it goes to an empty place in the connector on the stator harness. See picture 1
If the bent "pin" was not bent it would go to the orange wire on the stator harness connector for the CDI box. See picture 2. This picture also shows the white wire with a blue stripe and a black wire with a white stripe that was broken off but this is repaired
The blue seal and orange end cap that usually sit inside the CDI box connector on the stator harness was not present on my bike. Someone have taken off the blue seal and end cap. See picture 3
That they have taken off the blue seal and orange end cap i think makes it  more easy to bend a "pin" when putting the CDI box and connector back together
TrialsBreakersUK sent me a picture of a CDI box for a 2005 Gas Gas TXT 125 Pro and the CDI box they sent a picture of have only straight "pins". No bent pins.
Checking the number on TrialsBreakersUK I have the identical numbers except the last 4 letters and digits. The last 4 letters and digits on my CDI box ends with 4K08. On the CDI box from TrialsBreakersUK the 4 last letters and digits ends with 5D26
The bent "pin" and the last for letters and digits is the only difference of the CDI box on my bike and the picture of the CDi box from TrialsBreakersUK
Do any here know if the bent "pin" in the CDI box is supposed to be bent like it is, or do you think the "pin" have been bent by accident?
It must be more easy to bend the "pin" by mistace since the blue seal and orange end cap is missing and that makes room for more play so it is more easy to bend any of the "pins" on the stator harness
Hope any members here can help me out here
Picture 1. Bent "pin inside the CDI box. Is this supposed to be like this or is it bent by accident?
Picture 2. The bent "pin" would connect to the orange wire if the "pin" was not bent. Now that the "pin" is bent it would sit in a empty slot next to the black wire with a red stripe in front
Pic 2. If the pin was not bent it would go to the orabge wire (marked with a arrow).JPG
Picture 3. The blue seal and orange end cap on the CDI box connector on the stator harness
Pic 3. The blue seal and orange end cap is not installed on my 2005 Gas Gas TXT 125 Pro.jpg
Edited by thesaint
Here is a picture showing where the bent "pin" sit in the connector now that it is bent.See the picture 4 below:
The picture have red arrows and text on it
If the "pin" was straight like all other "pins" it would connect to the orange wire behind the empty slot in the connector
Pic 4. This is where the bent pin sits now when it is bent. 2005 Gas Gas TXT 125 Pro.JPG
Here is a picture of a CDI box i received from TrialsBreakersUK
No bent pins. But the "pins" in this box looks to be round while on the CDI box on my bike the "pins" are flat
All the letters and digits is identical except the last 4 letters and digits  to the CDI box with the bent "pin" on my bike
Edited by thesaint
Updated.
No reply are needed since i have straightened the pin that was bent. No way that the bike came like that from factory with a pin in the CDi box bent so it "hooks" up with the pin in front of it and goes to an empty slot in the CDI connector on the stator harness.
Now after i straighten the pin it goes to the orange wire on the CDI connector on the stator harness
Not easy to see which pin was bent on the CDI box
Edited by thesaint
