1978 Yamaha TY250 No Power
TRS_Trials
Hi All,
Hoping someone can help...
I have a 1978 TY250, but it's very flat when accelerating from the bottom. I have taken the flywheel weight off and that made a difference, but it's still quite flat and needs livening up.
Any suggestions?
Many thanks.
Timing and carb. , a 78 should be equipped with a Mikuni carb normally reliable, but if it's worn out it can mean trouble. I run my B model with the carb a LITTLE on the lean side, I insist little. from memory I setup the timing at 3.2mm BTD. Also I ran for a long time with a 0.005 inch tick head gasket, now back to original.
And follow JohnV8 advise
Guy
