SRH Posted July 13, 2019 Report Share Posted July 13, 2019 (edited) Does anyone know what exactly would be required to downsize the 300 to a 250, looking at doing just this as despite trying to sell it to buy a 250 it doesnt seem to be happening right now unless I take a large hit on a px so figure I’d be better off in the long run doing this then I guess when I do come to sell it, it’s an added bonus to have both 250/300 setups Looking at the parts diagrams its the cylinder, piston, o rings, gasket that's different but i'm not sure about the head its the S3 head on mine and presume the head is the same but not the insert? any help appreciated Edited July 14, 2019 by SRH Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted July 14, 2019 Report Share Posted July 14, 2019 im pretty sure its head piston and cylinder, thats it. You may need to look at taking weight off it has one. Quote Link to comment Share on other sites More sharing options...
huski Posted July 14, 2019 Report Share Posted July 14, 2019 Definitely piston and cylinder new base gasket,pretty sure the heads the same just change the insert.Finding the parts in good used condition might not be easy or cost effective tho Quote Link to comment Share on other sites More sharing options...
SRH Posted July 14, 2019 Author Report Share Posted July 14, 2019 Cheers! There’s no weight on mine it’s all standard now with the exception of a 10t and a slow throttle, pricing up at around £320 for all parts required that’s all new parts and a recon cylinder a somewhat small price to pay I’d say, wondering if jetting will need adjusting? Quote Link to comment Share on other sites More sharing options...
suzuki250 Posted July 14, 2019 Report Share Posted July 14, 2019 (edited) 2 hours ago, SRH said: pricing up at around £320 for all parts required Plus you could sell your old parts for around £150 (if they are in good condition) Edited July 14, 2019 by suzuki250 1 Quote Link to comment Share on other sites More sharing options...
huski Posted July 14, 2019 Report Share Posted July 14, 2019 Thought the parts would be more,as for jetting try it and see how it runs,nothing to lose Quote Link to comment Share on other sites More sharing options...
SRH Posted July 14, 2019 Author Report Share Posted July 14, 2019 Ive sourced a 250 complete cylinder, head and piston for a very good price, just looking on the parts diagrams and it also looks like the reed block and reeds are different any ideas? Quote Link to comment Share on other sites More sharing options...
huski Posted July 14, 2019 Report Share Posted July 14, 2019 Wait till you receive the cylinder and see if your reed block fits,bet they're the same Quote Link to comment Share on other sites More sharing options...
SRH Posted July 14, 2019 Author Report Share Posted July 14, 2019 16 minutes ago, huski said: Wait till you receive the cylinder and see if your reed block fits,bet they're the same Yeah actually looking further into the diagrams for newer models it looks like the reed valve block is only different on the Raga/Keihin carb, rather than the Dellorto i'm running but yeah ill find out when i get the cylinder this week, thanks for the assistance guys ill update once its done. Quote Link to comment Share on other sites More sharing options...
SRH Posted July 16, 2019 Author Report Share Posted July 16, 2019 I can report back.... works a treat, for anyone looking to do this you need : 250 s3 standard head insert 250 cylinder 250 piston and rings etc lower cylinder gasket, new inner and outer 250 head o rings, front Cush exhaust gasket and two front pipe to middlebox o rings. i would also recommend you replace the little end bearing at the same time you may as well whilst your there. Verdict: power difference is amazing, it’s so much easier to handle and still plenty of power Costs: I was lucky and managed to pick up a second hand cylinder with head for £60 +£20 on gaskets sure the best £80 I’ve ever spent. however if you need to or want to buy new you can do it for around £320 with a reconditioned cylinder. hope this helps someone else in the future ? any questions feel free to ask ? thanks all for the assistance Rich Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted July 17, 2019 Report Share Posted July 17, 2019 Ditch the slow throttle if you can, asap. Quote Link to comment Share on other sites More sharing options...
SRH Posted July 17, 2019 Author Report Share Posted July 17, 2019 7 hours ago, nigel dabster said: Ditch the slow throttle if you can, asap. Yeah i rode it today and thought that may be the way forward now, take it most novice riders use the fast throttle? Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted July 23, 2019 Report Share Posted July 23, 2019 On 7/17/2019 at 1:51 PM, SRH said: Yeah i rode it today and thought that may be the way forward now, take it most novice riders use the fast throttle? I dunno i guess so by default. its a little bit like learning to drive in an auto it just means you take longer to get where you need to be and can learn bad habits. As most will say its about throttle control. You dont learn that so easy on a slow imho. Quote Link to comment Share on other sites More sharing options...
