ty80 questions
balga
Hi everyone,
I just finally got my son a ty80 that was partially restored.
The bike is leaking fuel from the carby, I hope that it's just the float being stuck, does anyone know if this is a common problem?
Also, both clutch and brake levers seem a bit too big and hard to pull, does anyone here knows of a suitable replacement with an adjustable screw so that would bring the whole lever closer to the bars? I'm not really after shorter levers as they still need to be long to be pulled confortably.
Do you know where I could get a side stand?
The chain seems VERY loose, I either need to take some links off, or put a bigger sprocket, and I'd probably go with the latter as most people seem to suggest to gear it down, but what would be a good sprocket size in your experience?
