Robbo 240 Posted July 22, 2019 Report Share Posted July 22, 2019 Hi all Had my wheels rebuilt from my hubs a bag came back with the parts in the picture don’t know if they’re back or front or which order it’s a fantic 240 I’d like some help Quote Link to comment Share on other sites More sharing options...
nzpeterb Posted August 29, 2019 Report Share Posted August 29, 2019 Robbo, Hopefully you are not still trying to put this together, but here is the information you asked for. A is the spacer between the two front wheel bearings B is the spacer inside the back wheel C looks like the front wheel bearing ( Size 6202 on my 200). I hope you are replacing it. D is the circlip that holds the brake side bearing in place in the front hub E is the front wheel seal (25 x 35 x 6 mm) Regards, Peter Quote Link to comment Share on other sites More sharing options...
Robbo 240 Posted September 12, 2019 Author Report Share Posted September 12, 2019 Thanks for getting back to me , it is sorted now found the exploded drawing on here it’s helped a lot It’s a steep learning curve when you don’t know the wheels are great new bearings fitted with spacers inside! more stupid questions to follow Quote Link to comment Share on other sites More sharing options...
alberto Posted September 20, 2019 Report Share Posted September 20, 2019 light spacer 3 Quote Link to comment Share on other sites More sharing options...
