hoodie2 Posted July 29, 2019 Report Share Posted July 29, 2019 (edited) Hi....Can't seem to find a definitive answer on ignition coil resistance values for the rev3. seen 3 & 10000 ohms quoted but also saw a test for a leonelli coil suggesting 0.6 & 11k. Testing mine I'm getting 0.6 ohms on the primary and 4,500 ohms on the secondary. Can anyone tell me if this is out of spec? Thanks in advance. Edited July 29, 2019 by hoodie2 Quote Link to comment Share on other sites More sharing options...
Bilko Posted July 30, 2019 Report Share Posted July 30, 2019 This is from EVO Manual Quote Link to comment Share on other sites More sharing options...
hoodie2 Posted July 30, 2019 Author Report Share Posted July 30, 2019 Just had my stator rewound thanks. It's actually the HT coil I'm now looking at. I'm pretty sure its bad but was hoping someone could confirm. Quote Link to comment Share on other sites More sharing options...
konrad Posted July 30, 2019 Report Share Posted July 30, 2019 (edited) Are you measuring the secondary with or without the resistor cap (which is typicality about 5000 ohms)? Resistance reading don't tell the whole story. https://www.trialscentral.com/forums/topic/70835-montesa-cota-315r-no-spark-issue/ CDI ignition coils are fairly universal - a better way to test the coil is by substituting it into a working bike (almost any single with a CDI). Edited July 30, 2019 by konrad Quote Link to comment Share on other sites More sharing options...
hoodie2 Posted July 30, 2019 Author Report Share Posted July 30, 2019 I'm measuring without the plug cap. I found a crack in the plastic case, thought about an epoxy patch and then just decided to order a new one. Nobody close by I could borrow a coil from. Cheers. Quote Link to comment Share on other sites More sharing options...
