TL250 Petcock
Sean Dell
Good morning, everyone,
The original petcock on my TL 250 was gummed up and blocked.  So I ordered two aftermarket petcocks on eBay.  One was a useless thing,  The other was exactly like the OEM petcock (indeed, it was advertised as such), but there was a critical difference.  The flange on the mounting side of the OEM petcock is 2cm.  The flange on the new one is only 1CM, and therefore will not clear the standing seam on the bottom outer edge of the tank.
Has anyone else had to deal with this problem?  Any suggestions on where I might get a good petcock would be gratefully received.
SD
