steve ness Posted August 13, 2019 Report Share Posted August 13, 2019 HI,, I have a 2015 EVO 300 4t That I would like to check the valve adjustment on. I am having on luck in finding what the valve clearance should be.Any help is greatly appreciated. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
lineaway Posted August 13, 2019 Report Share Posted August 13, 2019 BETA has manuals online. Beta motos and Beta usa. Quote Link to comment Share on other sites More sharing options...
rcgods Posted August 13, 2019 Report Share Posted August 13, 2019 Inlet clearance 0.10mm Exhaust clearance 0.15mm. Taken from https://betausa.com/content/SUPPORT_PDF's/2008-2018%20Evo%204%20stroke%20engine%20manual.pdf Quote Link to comment Share on other sites More sharing options...
stu109 Posted August 14, 2019 Report Share Posted August 14, 2019 To get at the valves you are best to tilt the engine forward. To do this you need to take out the lower front mounting bolt and remove the two side struts. They say you can move the rad. to the side out of the way but I found it easier to disconnect it. You need to loosen the carb clip so that it disconnects from the airbox as the engine tilts I have a 2013 and twice "thought" I should check the clearances. However both times they were fine. I would say, given the difficulty of getting to and measuring the gaps, unless it sounds noisy or is not running well you could get away without checking. I have spoken to other Beta 4T riders and their experiences of checking the valves is similar to mine. Do you have issues that lead you to suspect a valve issue? Quote Link to comment Share on other sites More sharing options...
carlos Posted August 20, 2019 Report Share Posted August 20, 2019 Just finished doing the valves on my 2016 300. After 200 hours I was getting a little bit more noise than i thought it should have. Took about 3-4 hours, but i'm slow and methodical. One exhaust was tight, one a touch loose, one intake was perfect, the other a little loose. Quieted the bike down nicely, starts good to. Only glitch was when riding it around in the driveway the fan didn't come on, when i pulled the engine down i had unhooked the fan connection, nudged it back in and all is good. Thank you Billy Traynor for the good advice. Quote Link to comment Share on other sites More sharing options...
