Tranny vent overflow
Whiskyshooter
This is a common occurrence, as I have it happen to several bikes, especially after they have been laid down on their left side for anything other than a short period of time. am guessing that when this happens, oil is plugging the vent passage through the shaft, and when this happens, and the motor runs it is acting like a pump, a very slow pump at that. I normally stop this by attaching a short length of fuel line onto the fitting where the gearbox vent line attaches, and blowing into the line to clear the oil. There will be resistance as you are pressurizing the gearbox, but a couple of good strong pushes of air into the line should clear the oil. Make sure you clear the factory breather line and reservoir prior to reattaching. I have also replaced the black factory line with a translucent one so that I can see if oil is making its way up the line,
Spencer
