Montesa 315r Clutch Change
welly
Hi,
I have a 2002 Mont 315r - completely new to this sport
For the clutch plates should these be all fibre as I have been given a set by a friend and these are a fibre pack or should I be using a certain combination of plates. i.e fibre & cork etc.
I have counted 7 plates on my Mont which are fairly worn hence the change but due to the wear I cant work out the correct type.
Also can the clutch lever be operated to test the clutch action whilst the gubbings are stripped out of the basket?  I.e will any dot 4 leak out?
Could someone be so kind to explain.
Thanks
Welly
Edited by welly
