motovita Posted September 3, 2019 Report Share Posted September 3, 2019 (edited) The carb slide in my 199A is badly peened where it contacts the idle speed screw, I can't elevate the slide enough for a strong idle before the idle screw bottoms out in the carb body. I haven't found a new slide here in the USA and I'm not sure I can get one from the UK in time for the next meet. The slide is in good shape other than the contact spot with the idle screw. Has anyone repaired a slide like mine? I'm thinking I could thread a small brass screw into the slide to give a new surface for the idle screw to contact would give me back my idle adjustment. I'm guessing the slide might be plated zinc, or somesuch metal. Does anyone have any suggestions for me, or a US source for a new slide? I'll also be looking into a replacement carb, I want to stay somewhat period correct so I don't want an OKO or similar flat slide. Edited September 3, 2019 by motovita Quote Link to comment Share on other sites More sharing options...
b40rt Posted September 3, 2019 Report Share Posted September 3, 2019 Fabricate a longer idle screw ? 2 Quote Link to comment Share on other sites More sharing options...
pschrauber Posted September 3, 2019 Report Share Posted September 3, 2019 (edited) Parts for bing carbs have got very difficult to get that is true! And I know your dilemma, have gone through that by myself, what I did was get i functional Bing and a second replacemnet with better habits (Dell'Orto PHBH) for riding, now I can go back to the route of the original path in need. If you are interested I can give you (via PM) a ressource for Bing carbs which can sell you a new slide or even a brand new Bing carb either from German production (expensive) or made under licence in Spain with 28mm, albeit the last ones have the fuel supply on the "wrong" side other than that 100% original. There are guys in Germany that make slide out of brass to the Bing carbs of their twinshock Enduros and MX bikes here with enhanced design for better air flow and too to have more weight as more weight the slide have as less flutter will happen.I can proviode you with their adresses too, but that production will take time ... Last not Least the mentioned 28 or 26mm Dell'Orto even wih Malossi transparent plastic bowl is time correct, with 26mm the bike rides very good, with 28mm more agressive. Announcement of te Malosse plastic bowl in 1981 (mounted on a Dell'Orto PHBH): Edited September 3, 2019 by pschrauber Forgot to mention 2 Quote Link to comment Share on other sites More sharing options...
pschrauber Posted September 3, 2019 Report Share Posted September 3, 2019 And no the answewr to the silde repair, I would suggest to try out to use metal kned which has the properties of Aluminium. ToDo: 1. clean the slide, 2. the Surface where you want to apply have to be rough, (Dremel) 3. clean the surfaces again from any oil, 4. kned the two component of the metacl kned, 5. allpy where in need, 6. mill and grind away excessive material, (the properties are like aluminium). Brand: https://www.ebay.de/i/302159123726 3 Quote Link to comment Share on other sites More sharing options...
pjw123 Posted September 3, 2019 Report Share Posted September 3, 2019 Sling the Bing !!!. Old carbs are old school & invariably worn out. Mine came with a Dellorto which is OK , but could be better. I am told Mikuni works best, especially during hot conditions. Keihin also has good reports, but will liven things up a fair bit.. Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted September 3, 2019 Report Share Posted September 3, 2019 b40rt has it right - the consequences of a repair coming undone and going through the motor could be expensive. Quote Link to comment Share on other sites More sharing options...
rcgods Posted September 4, 2019 Report Share Posted September 4, 2019 The Bing carbs I have / had always float stuck and were absolute buggers! I have one left to get rid of and that will be swapped for a Mikuni Quote Link to comment Share on other sites More sharing options...
motovita Posted September 4, 2019 Author Report Share Posted September 4, 2019 I'd like to hear from anyone who's fitted a Mikuni to a late model Sherpa T as to how they did it. I took some measurements and found that the Mikuni is to short to span between the rubber intake and airbox boots. The necessary cylinder boot is stepped to two different diameters so I can't simply fit a longer hose, and the airbox boot is flanged at the airbox end so again not a simple hose swap. The carbs are readily available and affordable but I haven't found anyone who offers a ready to install kit. 1 Quote Link to comment Share on other sites More sharing options...
carl ekblom Posted September 4, 2019 Report Share Posted September 4, 2019 You need the Correct intake rubber Carb, Throttle cable Mikuni/Amal to Domino (assuming you have the Domino throttle) Air filter for 199B. Also good for 199A. Others I don´t know Inmotiontrials should be able to supply the parts needed Quote Link to comment Share on other sites More sharing options...
motovita Posted September 4, 2019 Author Report Share Posted September 4, 2019 On 9/2/2019 at 11:27 PM, b40rt said: Fabricate a longer idle screw ? A longer screw won't help, the tip of the screw contacts the carb body in the venturi and stops. I was able to remove a small amount of metal where the screw makes contact and get nearly one more turn on the screw. I'll try that and see how it works. Quote Link to comment Share on other sites More sharing options...
motovita Posted September 4, 2019 Author Report Share Posted September 4, 2019 2 hours ago, carl ekblom said: You need the Correct intake rubber Carb, Throttle cable Mikuni/Amal to Domino (assuming you have the Domino throttle) Air filter for 199B. Also good for 199A. Others I don´t know Inmotiontrials should be able to supply the parts needed I have that setup. Have you been able to stretch the airbox hose enough to secure it to the carb? Mine comes up a bit short, I wonder if my air filter hose is shorter than current production, it may be an original Bultaco 199B part. Quote Link to comment Share on other sites More sharing options...
carl ekblom Posted September 4, 2019 Report Share Posted September 4, 2019 OK at 199A. Should be OK also at 199B. My filters are later production from Inmotiontrials. Little bending is required to make them fit inside airbox. As you say, a good narrow clamp is needed at the carb intake, I remember that a wide clap caused some problem https://www.inmotiontrials.com/product/bultaco-sherpa-199b-air-filter-on-hose/ 1 Quote Link to comment Share on other sites More sharing options...
