RB45 Posted September 5, 2019 Report Share Posted September 5, 2019 I'm in the process of trying to rebuild a M116 Alpina basket case. Among the missing & broken parts is the resistor (or as my parts manual says, Ressitor Assembly 85.21-217). Does anyone know of a source for this part? OR, does anyone know the specs of the original part so I can look for a universal replacement? Thanks. Quote Link to comment Share on other sites More sharing options...
scot taco Posted September 5, 2019 Report Share Posted September 5, 2019 Try Bultaco Classics (Hughs Bultaco) in Crareyville NY. 1 Quote Link to comment Share on other sites More sharing options...
RB45 Posted September 5, 2019 Author Report Share Posted September 5, 2019 Already sent an e mail. Thanks. Quote Link to comment Share on other sites More sharing options...
rcgods Posted September 6, 2019 Report Share Posted September 6, 2019 I would not worry about replacing that part. It is only used as part of the lighting circuit. I would replace all the lights with LED bulbs and make it a closed circuit running off a small 12V battery (should fit in the headlight bowl). The original lights are 6V and frankly rubbish. Replacing with LED would make the machine a lot safer as it would be easier seen.I do have one somewhere that I removed from a bike so I will see if i can measure it up for you later. 1 Quote Link to comment Share on other sites More sharing options...
RB45 Posted September 6, 2019 Author Report Share Posted September 6, 2019 Thanks for the response. Quote Link to comment Share on other sites More sharing options...
