Softer springs
hannon
I'm not sure if this helps but have you looked at other Beta models?  The 08 Rev3 200 fork has a different part number than the 250.  I have long suspected that it is a softer spring.  Could the new 125s have softer springs?  Beta may know.  You could compare the rear shock springs to a 125 to see if they are different.  A suspension shop, like racetech, may also be able to provide a spring by looking at the originals even if they can not look it up by make and model.
