Robert n Posted September 15, 2019 Report Share Posted September 15, 2019 Hi been looking for oil and filters for my 300rr noticed the gearbox wants 540 ml and they come in bottles of 1000 ml does anyone just do 500 to get two out of a bottle with it need changing so oftern or is that two dodgy what oils do you all recommend thanks Quote Link to comment Share on other sites More sharing options...
Johnny Reggie Posted September 15, 2019 Report Share Posted September 15, 2019 I shop around for the best deals ‘cos prices do vary significantly. I keep a small stock so the 540ml doesn’t really become an issue. I stick with the recommended gear oil (plenty of alternative views on the forum tho’) From a usage perspective, you are asking if you can save the cost of 40ml of oil. At say 22 quid a litre you’ll save 88p....? I am planning a - pre Brexit - bulk panic buy when I remember to do so ? 1 1 Quote Link to comment Share on other sites More sharing options...
Robert n Posted September 15, 2019 Author Report Share Posted September 15, 2019 Yeah it’s not a lot when you look at it that way I’m just being tight Quote Link to comment Share on other sites More sharing options...
jrsunt Posted September 15, 2019 Report Share Posted September 15, 2019 460ml for the engine, 540ml in gearbox = 1 litre of 10w40 fully synthetic bike oil. Motul factory line is good. Clutch is crap and draggy until its properly warm, but eliminates the horrible judder and grabbyness that the thin stuff gives when it's really hot and upto temp. Depends how hard you ride it. Elf is probably better if your not abusing it too much 2 Quote Link to comment Share on other sites More sharing options...
Johnny Reggie Posted September 15, 2019 Report Share Posted September 15, 2019 1 hour ago, Robert n said: Yeah it’s not a lot when you look at it that way I’m just being tight Pulling your leg (the 40ml over p****s me off too). I feel, don’t go cheap on the oil and don’t mix oils (different brands or old and new) as far as you can anyway. jrsunt I’m sure knows what works... Interestingly, I was looking for an alternative to the Showa fork oil and the Motul Factory line is pretty close in spec 1 Quote Link to comment Share on other sites More sharing options...
Robert n Posted September 15, 2019 Author Report Share Posted September 15, 2019 Thanks it actually came with motul oil for both ill stick to that if its good stuff Quote Link to comment Share on other sites More sharing options...
Robert n Posted September 15, 2019 Author Report Share Posted September 15, 2019 2 hours ago, Johnny Reggie said: Pulling your leg (the 40ml over p****s me off too). I feel, don’t go cheap on the oil and don’t mix oils (different brands or old and new) as far as you can anyway. jrsunt I’m sure knows what works... Interestingly, I was looking for an alternative to the Showa fork oil and the Motul Factory line is pretty close in spec Glad its not just me 40ml isnt much but might matter Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted September 16, 2019 Report Share Posted September 16, 2019 8 hours ago, Johnny Reggie said: Pulling your leg (the 40ml over p****s me off too). I feel, don’t go cheap on the oil and don’t mix oils (different brands or old and new) as far as you can anyway. jrsunt I’m sure knows what works... Interestingly, I was looking for an alternative to the Showa fork oil and the Motul Factory line is pretty close in spec I really like the Red Line suspension fluid when I changed the oil on my 07 4RT. https://www.redlineoil.com/suspension-fluids I went down to 2.5 in both the front and had the rear done with the same to remove some of the sluggishness of the 07's Showa suspension of that year. Worked a treat! Quote Link to comment Share on other sites More sharing options...
Johnny Reggie Posted September 16, 2019 Report Share Posted September 16, 2019 For fork oil. Take a look at the cst measures at 40 degrees. You’ll see the Showa ss05 recommended for Showa front end is ~15 cst, as is the Motul racing line Very Thin 2.5w. Jonnyc21’s Like Water is thinner, their 2.5w comes in at 8cst. Don’t look at the manufacturers weight rating (SAE 5, 2.5 etc), look at the cst measure. Goggle it and you’ll find spec comparison tables... You have Tech forks, OJ-01 recommended oil, about the same at 15cst@40degrees. But you can find alternatives by the same method ?? 1 Quote Link to comment Share on other sites More sharing options...
