Ty175 Gear Problems
fatboyty175
If it won't shift with engine off, it's not your clutch.
Pull the left cover off, and make sure the whole area is cleaned out. If nothing is binding the shifter, you'll need to pull the clutch side off fo check the finger that moves the shifter drum. If the spring breaks, it won't grab the shifter drum. Rotate the drum manually a bit at a time and see if the the transm works. Beyond that, you need a manual and some tools.
k
